1371 code?
Old 08-05-2003, 06:39 PM
firebirdls1us's Avatar
Default 1371 code?
has anyone ever had a 1371 code? If so what is it? The car is a 96 z28
Thanks
Old 08-05-2003, 06:46 PM
30thWS6's Avatar
Default Re: 1371 code?
It's a problem with the low resolution signal coming from the optical sensor inside the opti-junk distributor. An LT1 with a distributor problem, never heard of that happening before.
Old 08-07-2003, 01:33 AM
taqwache's Avatar
have you ever had the water pump go out in the past or have you drivin in the rain before. more that likely you got water in there in the past and now it is causeing problems. you will probably have to replace it soon.
