COT enable temp and Torque management
i was just curious if anybody new what i should change the cot enable temp on my predator programmer after installing my long tube headers and off road ypipe. should i set the temp to the highest setting because now i no longer need that feature since i don't have cats. also what is the torque management feature, and what should i have my fans activation temp set at. i still have the factory thermostat.
What you should do for your fan temps is go for a cruise at 60mph for about 5min (highway stuff) monitor ECT and from what ever that reads add 5 degrees and run with that as your enable. Add 1 degree as your disable and you will then be working around the thermostats rating.
