OBD II port not working
Old 05-19-2008, 01:24 PM
PI HAT's Avatar
Default OBD II port not working
OBD II inop??? Ive been told that if the port doesnt power up a code reader that there is a fuse blown. Can anyone tell me which one. I checked all the fuses in the engine bay and in the dash. Some of the fuses are not clear...you know the big blocky looking ones. Also, I have a mulitimeter but dont know which wires should and should not have power, and of the power wires, how much??
Old 05-19-2008, 01:29 PM
LS1Tech Sponsor
06MonteSS's Avatar
look for a cigarette ligher fuse, or power outlet fuse...
it wouldn't be one of the big block ones...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old 05-19-2008, 01:31 PM
2001NBMZ28's Avatar
Check the CIG/ACCY fuse inside the car, even if it doesn look blown pull it out and check for continuity between the spades.
Old 05-19-2008, 01:34 PM
PI HAT's Avatar
wow, fast reply!! OK doing it now.
Old 05-19-2008, 01:53 PM
PI HAT's Avatar
I checked every single one and they are all still good. ???????
Old 05-19-2008, 02:02 PM
LS1Tech Sponsor
Mike@Diablosport's Avatar
Does your horn or cigarette lighter work?
Old 05-19-2008, 02:33 PM
koolrayz's Avatar
+1
Its one of the fuses on the drivers side of the dash
Old 05-19-2008, 09:34 PM
bLuE_DeViLz28's Avatar
im haveing the same problem i checked all the ones that i have but looks like im missing a couple lik 15a engine control. i just got hp tuner today and wanted to hook it up but my obd 2 inop
Old 05-21-2008, 06:48 AM
PI HAT's Avatar
Im pretty sure I checked everything I was supposed to check. I still have no power to the OBD II port. Does anyone know were I can get the schematics of the OBDII port? I got the multimeter out but cant find in the chiltens manual, how many volts the wires that have power are supposed to have. This is kicking my ***
Old 05-21-2008, 05:34 PM
Steve VanS's Avatar
On the OBD2 port:
Pin 16: +12v
Pin 4: Ground
Pin 5: Ground
Pin 2: Data from PCM
Quick Reply: OBD II port not working
