Swaped to 99+ pcm
Old 05-22-2008, 07:38 AM
-Freak-'s Avatar
Default Swaped to 99+ pcm
How do I get rid of the traction control light that is always on in the cluster now?
I pulled the cluster thinking it would be as simple as removing a bulb, that isn't so.
Old 05-22-2008, 08:00 AM
Eurospec2's Avatar
Pull the cluster apart and remove the bulb from the board, a little more involved then a simple plug and play bulb, but its really the only way to get rid of it.
Old 05-22-2008, 08:08 AM
-Freak-'s Avatar
Is it an led on the board? Or is it just simply another bulb that I can pop out once I get to the main board?
Old 05-22-2008, 09:06 PM
John_D.'s Avatar
Mine were all led's. Needle-nose pliers still pulled them out... of the board...
