Hiting rev limiter only with et streets...
I keep hitting the rev limiter at wot on the 2-3 shift. It doesnt do it on my street tires(245/50-16)et streets are 26x10x16. I have a predator and have the rev limiter set at 6200 and the shift set at 5900. My first gear shifts right at 6000 like I have it set but the 2-3 keeps going right past 5900. I dont have any idea on what else I can do. I dont want to raise the rev limiter. Anybody have any ideas.
Re: Hiting rev limiter only with et streets...
Lower your 2-3 shift by 1 mph if you dont want to raise your rev limit.The taller tire is the reason for the rev hit.
I would raise the rev limit to 6400,in 99 the Vetts had that as a stock rev limit.I ran a 6600 limit when stock internal set with HPP.
