HPTune Help
Old 05-27-2008, 02:59 PM
binarykungfu's Avatar
Default HPTune Help
Could someone check my tune/log and see if I would be able to run 150shot? I've posted my tune and a 3rd gear data log. I had a co-worker pull 6* out and I think my timing needs to be around 22-24* for 150? and I was looking at the log and it was higher than that in some places. Thanks
http://www.mediafire.com/?uatdceemscc
http://www.mediafire.com/?1nz9iwjoy1e
Old 05-28-2008, 09:01 AM
ZL1Killa's Avatar
post up at HPTuners also
Old 05-28-2008, 09:03 AM
stevegrizzle's Avatar
24 or lower should be good....youre only using a few cells wot spraying, look at the cells and put the timing at 23 or so....
Old 05-28-2008, 09:48 AM
LS1Tech Sponsor
hellbents10's Avatar
Don't forget to look at all of the adders, like IAT and coolant temp spark adders. Make sure you will achieve the commanded ignition advance that you want.
