Best Wideband for Hp Tuners STD version?
Old 05-29-2008, 12:04 AM
LS1C5Vette's Avatar
Default Best Wideband for Hp Tuners STD version?
I would like to get away with getting a gauge and use the laptop/hptuners to display the AFR, am I able to do this with the std version? If not what the best wideband to use?
Old 05-29-2008, 07:40 AM
ZL1Killa's Avatar
does your dongle thing have ports where you can plug stuff into?
I recommend Dean @ Dynotunenitrous I believe he is still a sponsor up here, but thats just My opinion, he hooked me up so what do you expect me to do
grab you the innovative LC-1 (for just your car) or LM-1 if you plan on tuning others also
Old 05-29-2008, 08:07 AM
69LT1Bird's Avatar
I bought the NGK NTK AFX wideband and it works great. Easy hookup and is was $250 shipped.
Old 05-29-2008, 03:07 PM
jmm98LS1's Avatar
After two years of fighting with the worthless LC1 and having the unit replaced twice, I finally gave up and bought a Dynojet Wideband Commander. It's an absolute breeze to wire, no finicky grounds, and it works flawlessly with my standard version of HPTuners (using the EGR circuit for logging).
Old 05-29-2008, 03:24 PM
ZL1Killa's Avatar
everyone is going to have mixed opinions...
i have had my lm-1 for over 4 years and had no problems
Old 05-29-2008, 04:45 PM
robertearl's Avatar
I have the LC-1 screwed into the front O2 bung feeding the narrow band input to the engine and the wideband to the Egr pin on the PCM. No problems yet.
Reb
Old 05-29-2008, 11:39 PM
LS1C5Vette's Avatar
I dont have EGR so how will that work for me?
Old 05-30-2008, 07:24 AM
ZL1Killa's Avatar
just forget what he said. you said you wanted to use a wideband gauge and wideband correct?
Old 05-30-2008, 04:23 PM
LS1C5Vette's Avatar
I would like to use my hp tuners for the afr gauge but I have the std version
Old 06-09-2008, 03:31 PM
y2konyxss's Avatar
i found a writeup a few days ago that i will have to find, it was great.
it showed how to use the AC presure switch wire to hook up to a wideband sensor to provide HP tuners STD the information from reading the AC presure switch PID to give AFR.
it was definately custom but worked.
but it meant no using AC while scanning Wideband with HPT.
if you are intrested i can dig that article up at.
EDIT: Found it: http://forums.corvetteforum.com/show....php?t=1705471
Old 06-10-2008, 07:57 AM
DirtyJohn's Avatar
My LC-1 has worked fine for a couple years.
Initially had problems but one RMA later and grounding it to the head and I log through HPT and EGR.
I couldn't beat it for the price.
Quick Reply: Best Wideband for Hp Tuners STD version?
