wiring fp sender to egr harness
Old 07-11-2008, 06:17 AM
11 Second Truck Club
Superado's Avatar
Default wiring fp sender to egr harness
attempted this:
http://download2.efilive.com/Tutoria...20Tutorial.pdf
ran into this:
both the egr & the sender pigtail have different color wires than the wiring instructions...
sender has black, grey & blue
egr has brown, red, grey, purple & white
any suggestions?
thanks,
al
Old 07-11-2008, 07:17 AM
DirtyJohn's Avatar
I send my Wide band 5v signal INTO the EGR brown (as do alot of folks), if that helps.
Old 07-11-2008, 08:37 AM
Superado's Avatar
edit...forgot the purple egr wire...
Old 07-11-2008, 09:16 AM
405HP_Z06's Avatar
Here's the pin out diagram on the Autometer 2246 sender:
I assume you are using a harness similar to this:
Now, to connect to the PCM you will connect this way:
1999+ LS1 PCM EGR Pin-Out:
Blue Connector:
Pin 41 - Black, EGR Pintle Position Ground - Grey wire
Pin 47 - Grey, EGR Pintle Position Sensor 5V Reference - Black wire
Pin 55 - Brown, EGR Pintle Position Sensor Signal - Blue wire
Old 07-11-2008, 10:11 AM
Superado's Avatar
DirtyJohn...that info is correct...thanks
405HP_Z06...that info is correct for the pigtail, however I have just found the egr harness info for the truck...thanks to cablebandit
from the gm dvd info on the egr harness,
brown 0-5
grey +5vdc
purple gnd
the pin config. of my sender...
http://shed51.com/sensors.htm
and the pic of my sender pigtail below,
we have come up with this...
sender/pigtail to egr harness
Blk (gnd) to purple (gnd)
Grey (+5vdc)to grey (+5vdc)
Blue (0-5) to brown (0-5)
Old 07-11-2008, 11:31 AM
405HP_Z06's Avatar
brown 0-5
grey +5vdc
purple gnd
Are you using the Autometer FP sender? If so, you have the power and ground wires reversed.
It should be:
Grey (gnd) to purple (gnd)
Blk (+5vdc)to grey (+5vdc)
Blue (0-5 signal) to brown (0-5 signal)
Old 07-11-2008, 01:27 PM
Superado's Avatar
It should be:
You sir are correct!
I do not have the AutoMeter sender, but the pin out is the same on the Rockwell:
I was looking at the plug end of the pigtail the same as the sender's pin out, which is incorrect because it is actually a mirror of the sender...
good catch...thanks!
Old 07-11-2008, 03:23 PM
405HP_Z06's Avatar
Old 07-12-2008, 10:42 AM
DirtyJohn's Avatar
I'm glad you posted this, I would like to hook something like this up.
Thanks.
Old 07-12-2008, 10:50 AM
Superado's Avatar
got it wired up last night...
used bullet connectors so I can un-hook and use with a 2-bar map for logging boost as well...
gonna try to log fp today and try to figure out why I'm not getting enuf fuel @ WOT...
Old 07-12-2008, 02:57 PM
TAQuickness's Avatar
You should be able to run your 2bar MAP thru the existing MAP wiring. Check out the custom OS tutorial for setting up 2 and 3 bar MAPs
Old 07-12-2008, 03:03 PM
Superado's Avatar
I'll take a look at that...thanks...
I got the scan tool set-up to log fp...
works great!
Quick Reply: wiring fp sender to egr harness
