Idle goes lean in open loop
Old 07-12-2008, 10:48 PM
02WS6FREEBIRD's Avatar
Default Idle goes lean in open loop
While driving in open loop the AFR is a little lean like in the low 15's but when sitting and at idle the afr goes real lean in to the 17's, I have DFCO off correctly I think, does any one know what is wrong?
BTWI am reading off a AEM WB gauge.
Old 07-13-2008, 03:24 AM
macca_779's Avatar
You are obviously tuned for open loop at idle and your fuelling is incorrect if that is not what you are commanding. Your MAF and/or VE is not tuned correctly.
Old 07-17-2008, 01:50 AM
Think it is me VE...thanks
Old 07-17-2008, 06:49 AM
Frost's Avatar
if the the AFR is fine at girst when idling and then tapers lean, look at your IAT, it could be getting heat soaked.
