Why is my abs inop light on after gear change?
its a 1999 ws6 don't know to much about the set up but the mechanic said he finished in the dark so I thought it might be a wire not plugged somewhere but I don't know where to start looking .
If you don't have ASR/TCS it's 3 channel, check the sensor connector on top of the pumpkin like said. If you have ASR/TCS it's 4 channel, check the sensor connectors at each rear wheel.
