Code Reseet
Old 07-31-2008, 09:49 PM
xXSilencerXx's Avatar
Default Code Reset
How do reset codes disconnecting the battery? You take off the negative cable right? Is there an amount of time you need to wait before you put it back on?
Old 08-01-2008, 08:43 AM
LS1Tech Sponsor
06MonteSS's Avatar
yeah, pull the negative cable for about 10 minutes... while it's off, turn on your lights and step on the brake pedal... this will fully drain any residual power that is stored in the system, and you'll be all set.
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old 08-01-2008, 11:14 AM
Ok, thanks!
