Max Timing for idle??LT1
Old 08-01-2008, 07:26 AM
lt170chevelle's Avatar
Default Max Timing for idle??LT1
Ok my setup is in sig. but am wanting some opinions on maximum or best timing , in idle , without surging and poor idle . Just trying to get best idle and fuel economy.
Old 08-01-2008, 07:35 AM
RickyMartinZ28's Avatar
I think stock is 20, I'm running 22 right now without a problem, it could probably handle more. I have a cam though so mine might be a touch different. I'm really not sure with yours being turboed etc...
-Rick
Old 08-01-2008, 12:09 PM
yeah that is about where mine is at now..i think i had added a degree or two when i first started playing with it.The way i look at is the timing in idle should be no different than a n/a car.might be a little different with a supercharger depending on the head unit and such.but anyways anybody else have any input on this?
Old 08-01-2008, 01:13 PM
Frost's Avatar
Once idle is solid, move the timing around and note MAP readings. Try and get the MAP readings as low as you can.
Old 08-04-2008, 11:49 AM
ok should i change the closed tps table or the main spark advance table?
Quick Reply: Max Timing for idle??LT1
