low oil light!??
Old 08-06-2008, 10:10 AM
Banging some gears
greyghost4x4's Avatar
Default low oil light!??
my low oil light has come on and stayed on for several months now but i check my oil regular and it is always full of oil!! anyone have this problem before or have any advice.. im guessing it's just a bad sensor. if so does anyone know what sensor it is?
Old 08-06-2008, 10:31 AM
Moderator
jimmyblue's Avatar
There's a fat plastic connector out the passenger's
side of the oil pan (or real low on the block, I forget),
low enough to maybe get snagged.
Old 08-06-2008, 10:37 AM
2001NBMZ28's Avatar
Yeah check the wiring/connector to the sensor - it's on the passenger side of the oil pan.
Old 08-06-2008, 02:56 PM
Banging some gears
isnt this the crank sensor? it's been awhile since i've looked under the car
Old 08-06-2008, 03:08 PM
2001NBMZ28's Avatar
No, it screws into the side of the oil pan - just the low oil level indicator. Illuminates the light when you're about 2 quarts low. Newest GM PN I have is 12603782.
Old 08-06-2008, 03:29 PM
veee8's Avatar
I have changed a few out, starting with GM 3.8 v6's and on to LT1's and then the LS. It is a float that screws into the side of the pan, A lot of time they will start to leak through the center of the sensor where the connector is.
Old 08-07-2008, 09:20 AM
wait4me's Avatar
If you unplug it, the light should go off i think. IF it dont shut off then you have a melted wire somewhere.
Old 08-07-2008, 03:19 PM
Banging some gears
ok guys thanks alot! i'll try this as soon as the weather clears up.. stormin its *** off here right now
