help with vats and other wiring
Start with if the vats isn't working what will happen? Will it crank will it fire and die or just do nothing. Problem I'm having is that I have a 98 car that I swapped all the harnesses over from a 2000 not just the engine an computer I mean the whole interior harness also. Everything works but fuel pump won't turn on and starter won't crank. I also have no dash lights but that's not a big deal. NOt sure if the vats has to be deleted or I am overlooking some wiring connectors somewhere.
Actually the fuel pump might work I think I left a plug under the car unplugged just thought of that but still no starter.
