98 computer to a 99-02 conversion
I know if I convert with repinning the harness I will lose my cluster but does anyone know if I put a newer cluster (99-02) if they will still work assuming the body harness' are the same.
You will not "loose" your cluster. The fuel gage will not work. The rest will. If your tuner uses EFI Live he can make the fuel gage work with the software and +1 wire.
If you want to upgrade to a newer cluster you will have to re-pin the cluster connector and splice in a serial data wire for it.
Much less work to do the former.
