Is there such a product or device
want to know if there is a product that has a lean shut down and is also a timing tuner in one? I have seen lean shut down with window switch and timing tuner with window switch but i already have a window switch and want to know if i am gonna have to buy both products and use all three or sell mine and just use the two new products or if there is one that has both or even all 3 in one.
I use a product that the nitrous guys use that is called Trick gauges.
The more expensive gauge will control everything nitrous related and looks nice too.
You can run a wideband serial input right up to it and it will show you af, have a min and max activation based on af,
it is also a progressive controller, and controls bottle heater to a set temp.
