Autometer wideband logging
Old 08-15-2008, 11:47 PM
02SSLE's Avatar
Default Autometer wideband logging
Hey guys can anyone tell me how to get my Wideband to work with EFI live? I have the wires ran over to be able to log. I have looked under PID and no Autometer. About 10 others but not autometer. Can someone help me please?
Thanks
Old 08-16-2008, 11:57 AM
02SSLE's Avatar
surely someone has ran into this.
Old 01-26-2012, 04:52 PM
Steve-O-08's Avatar
Bump for the same info.
Old 01-26-2012, 06:50 PM
joecar's Avatar
Can you point me to the user manual for your specific model of wideband...?
I need to know the AFR at two different voltages...
then we make a pid for it, or if it is identical to another wideband we can use its pid.
Old 01-27-2012, 01:01 PM
cyipher's Avatar
its more complicated then that cause you can adjust the output....
http://www.autometer.com/productPDF/1143A.pdf
Old 01-27-2012, 01:41 PM
joecar's Avatar
How do you adjust the output...?
Can you set it to output the same voltage as the LC-1...?
i.e. 0V = AFR 7.35 and 5V = AFR 22.35
if you set it like that then you can use the LC-1 pid.
Old 01-31-2012, 12:57 AM
Steve-O-08's Avatar
My wideband is 0v @ 10.0 AFR and 4v @ 17.0 AFR. Any ideas?
Old 02-11-2012, 02:12 PM
joecar's Avatar
Hi Steve-O,
(AFR-10)/(v-0) = (17-10)/(4-0) = 1.75
(AFR-10) = (v-0)*1.75 = v*1.75 - 0
AFR = v*1.75 + 10
^ that is the equation you put into a calc pid [ if there isn't a pid already defined for that ] (pm if you need help with that).
