Fuel cut off not making sense
I have HP Tuners, but my car was tuned by a couple diff people b4 I got my own software. I just loaded my tune into the laptop over the weekend so I could adjust for the 4.30 gears. I was looking around at the file and in the fuel cut off chart it still shows the stock settings of 6200 off 6199 on My car has had the limiter set well above this for 2 yrs. Did they change it some where else?
I've raised the limiter on a buddies GTO and that's where I made the change. After seeing that, I even took my car out for a spin to verify it pulled past that, and it does.
Anybody care to shed some light on this situation?
Thanks, Brian
Thanks, Brian
Are you looking at the settings under RPM LIMITS?
Mine uses the "CUTOFF RPM vs. GEAR" ~ "NORMAL" table right below that section
You can always attach a copy of your tune to this thread and anyone familiar with HPTuners can verify.
