Tuning VE question
Tuning VE question
I've disconnected MAF, turned off LTFT, reset fuel trims and wanted to do logging via STFTs.
The problem is that I think one of my O2s is shitting the bed. At first, it's fine, then eventually it nearly flatlines, and my STFT maxes out on that bank. I'm basically just asking if the o2s are taken into consideration for STFTs or not while in SD mode. I'm assuming they are, which makes sense looking at my log.
yes they are used in CLSD. If you must use STFT to dial in VE and not a more accurate WB its always good to know you have solid data coming out. If you are sure one sensor is talking bullshit.. Use the other one.
Fuel Trims, short or long are a completely different component of the beauty of internal combustion.
In short, yes they are taken into consideration.
