blue PCM plug 2006 GTO
Old 09-01-2008, 10:43 AM
kochevy67's Avatar
Default blue PCM plug 2006 GTO
I have the motor and trans out of an 06 GTO for my Chevelle. I have the wiring and ecm along with the pedal, the question I have is I need the wiring that connects to the blue plug on the ecm. Does anyone know where to get it besides the dealer and what is the part number in case I have to order it from a dealer. Thanks
Old 09-01-2008, 10:54 AM
poconojoe's Avatar
Are you looking for the plug or the harnees with the plug?
Is the PCM a service number 12583659?
Old 09-01-2008, 12:53 PM
slow's Avatar
Look up "eficonnection" on google, and they have it available.
Ryan
Old 09-01-2008, 03:06 PM
kochevy67's Avatar
I need the plug and the harness. I was also wondering if it was one harness to the pedal that hooked up to the ecm as well. I guesss what I am trying to say is I wanted to know if it is 2 separate harnesses. I appreciate the responses from you guys.
Old 09-01-2008, 08:29 PM
poconojoe's Avatar
I could get you the number for the plug, covers and pins, but not the whole harness. One just went across Ebay, so you could watch there. By the way, if I need connectors or pins, I'd normally use mouser, they're a lot cheaper then GM or most other places, if they carry it.
Old 09-02-2008, 03:28 PM
ssvolvo's Avatar
Speartech has them. Good stuff too. Great to deal with.
Just tell him you need C1 connector for an E40. It's the same one he uses for his reflas cable.
Old 09-02-2008, 04:43 PM
squarehead's Avatar
here's the connections for the blue connector
http://www.ls2.com/boggs/LS2/Enginec...controls07.JPG
looks like it is more than one harness, at least one set of wires to the pedal and probably another harness or two for other connections
here's a site that sells the blue connector
http://www.eficonnection.com/eficonn..._pigtails.aspx
Old 04-26-2009, 03:04 PM
Snyper's Avatar
I lost my C1!!!! my car is just about ready to start too dammit!
