Edit( IAC and RAF) changes for G5X2 cam
Re: Edit( IAC and RAF) changes for G5X2 cam
I don't think that there's a consistent value you can use to for a cam change. The tunes seems to vary from car to car. I've seen what works for one car doesn't necessarily work for another car identically modded. You might try increasing both tables by 20% as a start and then adjust from there. It does seem like there is a correlation between these two tables so be careful not to over adjust on one.
Good luck,
Richard
Good luck,
Richard
Good luck,
Richard
Good luck,
Richard
joel
