Advice: OLSD or OLMAF
I have been working on my tune off and on for almost a year. I had to get away from it for a while because I bought another house and winter set in, busy with job etc...
I spent many hours trying to get all of the surge out of it. After being certain my fueling was right by performing AutoVE multiple times, I worked with the timing, learning tables, TC and TF. I can get it good but not great. Unless I run it in open loop. In open loop, 99% of the surge is gone and I only get a slight bump in rpms when coming to a stop as it downshifts. It has excellent street maners in open loop and I'm tired of chasing my tail trying to get it to behave everytime I put it back in closed loop.
So I have decided to upgrade my operating system to EFI Live's COS 3 and run open loop all the time.
What are the benefits to running with the MAF when in open loop? If there arent any or many I'm going to remove it from the car. After AutoVE it runs rich with the maf enabled in open loop, which I can fix but I'm not sure there is any benefit to it. Right now I have it running OLSD and my fueling is spot on. My car is not a DD by the way, and I'm going to install an AFR gage so I can drive it without the laptop all the time.
Thanks for any feedback.
Thanks, that is what I am planning to do at this point unless someone can give me a good reason to use the MAF. I think all I would have to do now is upgrade to COS3 and dial in the IAT VE multiplier table.
Jedi Master
I have the same problem...OL is wonderful and CL is horse **** in comparison but still drives pretty well.
I've been running OLMAF the past few days just working on my airflow tables and the car drives like a dream. I would however do OLSD(which I'm doing soon for retune reasons).
