HP tuners pro, where to find IAC steps reading in the scanner?
Old 09-16-2008, 09:27 AM
Abdullah's Avatar
Default HP tuners pro, where to find IAC steps reading in the scanner?
i have HP tuners pro for my 2000 LS1 camaro, where can i find IAC steps in the VCM scanner?
Old 09-16-2008, 09:56 AM
69LT1Bird's Avatar
I think the scanner is the same as the standard version. You have to add the pre-made PID to the Table Display.
< pick a cell in the table display
< right click in the cell
< select PID List
< Select Engine
< Idle
< IAC position
< Closed box
< save config file
< start scanning
Old 09-16-2008, 10:11 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
Exactly, it's called IAC position or count, not steps.
Old 09-16-2008, 01:34 PM
Abdullah's Avatar
< select PID List
< Select Engine
< Idle
< IAC position
< Closed box
< save config file
< start scanning
thanks for the reply. right now i'm not near my car but i tried your way and i didn't find PID list after i right clicked in the cell in the table display? what i found was insert and it was not highlighted?
i found for the lower 2 cells when i right click configure which will show
1. <undefined> 2. <undefined> name: , enable trigger, disable trigger
but i can't use them there they are not highlighted. i found
[PID. 2200] IAC position in the help section of enable trigger
but still i don't know how to show the IAC position in my HP tuners scanner. my HP tuners is the pro version.
any one with the HP tuners pro who knows how to show the IAC position ?
thanks for help.
Old 09-16-2008, 01:50 PM
69LT1Bird's Avatar
Make sure you do not have any data logs open or the selections are grayed out. Close the logs first.
Old 09-16-2008, 02:01 PM
Abdullah's Avatar
thanks, it worked!. actualy the log for my mods in the sig with the stock tune was open i closed it then opened the table display, did the steps you described and the IAC position was shown in the table display.
Quick Reply: HP tuners pro, where to find IAC steps reading in the scanner?
