06' Pontiac G6
Old 09-19-2008, 07:53 PM
DevonsZ's Avatar
Default 06' Pontiac G6
Well I went to tune the ladys g6 tonight and it read ok but when writing it failed and said there was a connection error and stopped. Now the thing wont start or crank for that matter.
What can I do? This is using Hp Tuners
Old 09-19-2008, 09:10 PM
Jedi Master
Gh0st's Avatar
You tried doing the fancy pull the battery trick?
Old 09-20-2008, 06:18 AM
LS1TECH Sponsor
foff667's Avatar
I believe the G6 has an E67 pcm and requires a write entire. You probably were doing a write calibration only and got a 1C0000 error which is explained in our help file.
Old 09-20-2008, 08:56 AM
DevonsZ's Avatar
I ended up unpluging it for awhile last night before giving up and it worked. Thanks for the replys guys.
