o2 bung lc1
Old 09-25-2008, 03:53 PM
FiFdYnUtz's Avatar
Default o2 bung lc1
so i bought an lc1 wideband setup back when i was going nitrous and since sold it and waited to do the install until i got headers/Y so now i am asking, where do i get the o2 bung for the lc1 wb sensor? or what thread size is it if i can use a regular nut or something...also where should i put it? any info or other help on the install i should know would be greatly appreciated..thanks!!!
Old 09-26-2008, 06:27 AM
sreve's Avatar
moates .net has them $8
muffler shop likely has them
Old 09-26-2008, 07:54 AM
robertearl's Avatar
Just put it in the stock location and wire the analog out 1 to simulate the narrow band and wire that back into the PCM.
Reb
Old 09-26-2008, 08:14 AM
WhiplashDVD's Avatar
i get mine at NAPA, i forget the part number. Good luck depending on who is working they might say "a bung you want a bung?" It takes some explaining but eventually you get through.
Old 09-26-2008, 12:12 PM
kbracing96's Avatar
Thread size is 18mm/1.5
Old 09-29-2008, 06:35 PM
FiFdYnUtz's Avatar
thanks guys!
Old 10-02-2008, 03:58 PM
FiFdYnUtz's Avatar
now i decided to tune out the rear 02 sensors, would it work to put the wideband in one of the rear locations?
Old 10-02-2008, 10:12 PM
wait4me's Avatar
Yeah that should work just fine.
Old 10-02-2008, 11:23 PM
Frost's Avatar
If you need bungs or plugs in the future, I have an assortment of them here: http://www.lsxtune.com/shop/index.php/cPath/103_104
