help with headlights!!
hey guys, just a quick question about my damn headlights.. the ***** been killing me forever.. I have a 99 ws6 and my headlights stopped popping up. I've checked all fuses and wiring and everything is fine. Also, I believe the multi-function switch went out as well bc my cruise and blinkers stopped working. I was wondering if it could be the multi-function switch, since it does operate the high beams. Just wanted to make sure before I go spend $$$. Thanks again.
Whether the headlights pop up or not should have nothing to do with the other lights working. So you have a problem, probably electrical, that has to with more than just the head lights. You have checked the fuses. Did you buy a couple of new ones and try them or just pull the ones you have and look at them? You can't always see if the fuse is bad by looking at it. Get some new fuses, they are cheap. Then move on to the relays.
