Vent Guages ( Wiring )
If you pull the radio out and the louvers out of the vent, it's pretty self explanatory. Once you pull that stuff out, you will see what I mean. There is a small cavity filled with foam that will allow you to get wires from behind the radio up in to the vent.
I found a write up with that today a`actually on a different site. For some reason I was thinking I could wire them up through the defrost spot but I was wrong lol
Thanks for the post
Thanks for the post
