burning oil
Old 05-20-2009, 02:45 PM
DCfirebird967's Avatar
Unhappy burning oil
hey guys my car has always burned a little bit of oil since i got it, but lately its becoming worse. i just changed my oil with purple 10w-30 1000 miles ago and i was already a court down today. and its not leaking any at all. got any suggestions to stop this?!?
Old 05-27-2009, 06:02 PM
doomsdaymachine's Avatar
suppose is normal to burn a quarter now and then, if i member good
a friend told me that he had that problem and sum seal was bad and the oil will end up going to the headers...
Old 05-28-2009, 01:26 AM
4WOFURY's Avatar
Have you tried playing with different oils? Some engines will burn one but not another. If Royal purple isn't working out for you, try something else.
Old 05-28-2009, 09:15 AM
99_SS_LS1's Avatar
yeah stop RP. I used it until my last oil change, and my consumption issue has been cut in half at least
Old 05-29-2009, 12:52 AM
bryankuhn's Avatar
Default oil consumption
I dont know if you have checked this but i was burning alot of oil for awhile and i read somewhere too check the pcv system. The pcv itself and the the hoses that run between it and the valve covers on both sides. I was burning around a quart every 1,000 miles. I checked my lines and the pcv and they were all gummed up bad i got rid of the lines and replaced them with radiator hose and put a new pcv in and now it doesnt burn a quart every 3,000 miles and i have 164,000 miles on the car. Just a heads up on something you could check cost me a total of $20 too fix my problem hope its something easy for you. anything else you need too know just ask thanks, ramair1999@hotmail.com
Quick Reply: burning oil
