pics of my ws6
Old 06-14-2009, 11:26 AM
jdcws6's Avatar
Default pics of my ws6
just thought id share a few pics of the car, hope u guys like
Old 06-14-2009, 01:02 PM
Jersey Mike's Avatar
great color!
as you can tell from picture 2, she needs to be lowered a tad
car looks very clean though. thanks for posting pics
Old 06-14-2009, 01:05 PM
jdcws6's Avatar
yeah it will be lowered soon hopefully, its kinda a big gap lol
Old 06-14-2009, 01:39 PM
Dan
Dan's Avatar
That was my thought when I 1st saw the pictures. It would look even better lowered. Nice car.
Old 06-14-2009, 05:43 PM
LCplmarine98's Avatar
Looks good, nice car man.
Old 06-14-2009, 07:29 PM
02BLACKTAWS6's Avatar
Looks great. Love the color.
Old 06-14-2009, 10:10 PM
02cetransam's Avatar
car looks great!!
Old 06-14-2009, 11:45 PM
SIC FUQR's Avatar
love the rims on that car
Old 06-15-2009, 01:30 AM
jdcws6's Avatar
thanks for all the positive comments guys
Old 06-15-2009, 01:38 AM
ehnihl's Avatar
Sweet ride and nice pics...
Old 06-15-2009, 05:52 AM
Bird Man's Avatar
That car looks great!
Old 06-15-2009, 04:32 PM
NOS4EVER's Avatar
+10 for she needs to be lowered
Old 06-15-2009, 06:41 PM
jdcws6's Avatar
thnks guys, yeah it will be lowered soon
Old 06-15-2009, 09:55 PM
xRelapse13's Avatar
car looks good. What's done to it to get those numbers?
Old 06-15-2009, 10:57 PM
jdcws6's Avatar
-ls1 aluminum block
-ls1crank, 3.622 stroke
-scat ls1 h beam connecting rods, .927 wrist pins, set of 8, with upgraded apr 2000 bolts
-diamond racing ls1 forged flat top with 2cc valve releifs, 3.905 bore, 3.622 stroke, 6.122 rod length, .927 x 2.50 wrist pins included
-mahle racing 3.905 pro select piston rings 1.5/1.5/3.0mm file fit
-camshaft bearing set for ls2 and 2nd gen ls1 block
-clevite connecting rod bearings, ls1, per bearing,for stock crank applications
-clevite main bearing set for ls1 applications, stock
-gm bolt for ls1/ls2 side main cap and ls2 rear cover
-gm ls1 oil restrictor
-gm ls1 oil galley core plug
-gm ls1 large cooland plug
-gm engine block small coolant plug, lsx based engines
-precision race comp stg 2.5 5.3 heads
-v3 cam 231/234 .643/.598 111.
-ls7 lifter kit
-in motion ls1 double roller timing set with torrington bearing
-ls1/ls2 cam retainer plate
-arp lsx cam retainer bolt kit
-arp ls1/ls2/ls6 cam bolt kit
-ls1 lifter tray bolt
-ls1 lifter trays
-ls1 cylinder head gasket, pair
-ls1/ls6 cylinder head bolt kit, per cyl head
-ls1/ls2 timing cover gasket
-ls1/ls2 rear main seal housing gasket
-valley cover gasket
-ls1/ls6 oil pump and o ring
-ls1/ls6 balancer pully bolt
-ls1 exhasut manifold gasket
-ls1 oil pan gasket
-ls1 water pump gasket per side
-lsx rear main seal
-ls1 front cam seal
-stg 4 clutch and flywheel
-fast ls6 intake
-pace setter headers
-slp lid
-full slp loudmouth exhaust
-39lbs injectors
and a few other things are done to the car as well as far as subframe connectors etc etc
Quick Reply: pics of my ws6
