Formula swap???
Formula swap???
I have a 95 T/A vert. car that is a project I'm rebuilding and have an odd question. The pass. side rocker moulding is broken and I haven't been able to find a replacement for some odd reason. The front bumper cap is also damaged a little as well. I have a 96 formula roller that I'd considered swaping the front and rear bumpers to my vert car and doing awy with the side moulding and rocker ground effects. First do you guys have any pic's of a formula conv. car I could check out? I like the way the T/A's look with the large fog lights but I'm considering this swap. What goes in the two openings on the formula front-end in above the large ducts, mine are empty there(the formula car was stripped)? I'm looking for ideas suggestions, pro's and con's from you guys! Thanks.
-SS
-SS
