Forgot where to look...
Old 12-13-2009, 12:59 AM
FenixSS's Avatar
Default Forgot where to look...
Had this problem when I first got my 2000 Firebird. My turn signalsin dash as well as outside the car (left and right) seem to be stuttering flash (irregular interval) or sometimes just solid signal (doesn't blink). Now this problem went away when I just cleaned the bulbs. There was the yellow jelly stuff (forgot what it's called) gumming up the socket.
What I can't recall at the moment is:
1. Do I need to purchase a special cleaner? Or do I just use like a toothpick to scrape it out?
2. Do I need new bulbs? If so what's the part #?
3. Is it possibly linked to a battery or alternator problem?
Any feedback is greatly appreciated.
Old 12-13-2009, 09:34 AM
PontiacSpeed's Avatar
This has also been happening to me quite a lot. Any information would be appreciated.
Old 12-13-2009, 10:52 AM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
You can use CRC Electric Cleaner to clean out the socket. However, the sockets are notorious for going bad.
Trying new bulbs would be the cheaper route.
It's highly unlikely that it's a battery or alternator problem. You'd be experiencing other problems along with the light issues.
Old 12-13-2009, 04:11 PM
FenixSS's Avatar
Manual didn't come with the car, anyone know the bulb part #s off hand?
Old 12-13-2009, 11:00 PM
Super-Bat's Avatar
Parking light/Turn Signal/DRL= 3157A
Old 12-14-2009, 08:39 AM
cambirdracing's Avatar
that yellow jelly stuff is a dielectric grease to keep moisture out of the socket. Keeps the corrosion down.
Old 12-22-2009, 03:37 AM
FenixSS's Avatar
Oh, so the grease is desirable then? Is it the bulb that's going bad or the socket? y2k ta mentioned trying new bulbs but I'd like to isolate the problem to either the socket or the bulb.
Old 12-22-2009, 07:30 AM
eseibel67's Avatar
Yes, the dielectric grease is good, but when it gets old, it's crusty and gross.
Clean it out and put new grease in it.
Old 12-26-2009, 08:52 PM
Copy & Paste Moderator
VIP1's Avatar
Here are the manuals for the 1993-2001 Firebird and Camaro:
http://www.f-bodyhideout.com/techman/
