Project V6 Firebird
Old 07-28-2012, 06:08 PM
  #261
WarShrike's Avatar
Had to mill the notches open a little more to accept the hydraulic lines on the bellhousing. Glad I had a friend with a bridge port.
Trans is bolted in, waiting on crossmember. Found a broken knock sensor (female connector wiggles around a lot), probably one reason why TSP had some odd KR when doing the dyno runs.
Wrestling that **** in was a lot more enjoyable than the Auto.
Old 08-07-2012, 10:26 PM
  #262
WarShrike's Avatar
Dropped my crossmember off to get modified. Needed 1/2" more to get it to reach the bolt holes on the chassis because of the adapter plate.
Wiring is almost finished, hopefully a week or two and we'll be done, but who knows.
Old 08-08-2012, 10:20 PM
  #263
silverWS.6's Avatar
Props to you man! I just went through all 14 pages and great work, love the wheels also! I might have missed it but what sizes are they?
Old 08-09-2012, 03:23 PM
  #264
WarShrike's Avatar
17" x 9.5" and running 275's.
Old 08-26-2012, 12:22 AM
  #265
WarShrike's Avatar
Progress is being made, I'm a wiring newb so some things like wiring in the reverse lockout solenoid has been a challenge. I'm wiring it into the brake as I didn't feel like trying to figure out the rats nest of the pcm pinouts and couldn't get anything reliable off the old auto pigtail. I've run a grommet through the trans tunnel so I can run my wires cleanly through there and under the console and dash. I'm excited to get things finished and they look to be getting really close.
Especially after this:
I had to modify my T-56 crossmember. It takes a lot of *****/faith/stupidity to modify a brand spanking new crossmember for 1/2" of clearance needed because of the spacer. With a stock crossmember, there's probably enough tolerances in the manufacturing process that you might be able to bolt it up lol! Took it to a welder that used to work for the USAF, damned good guy, has a nice little piece of stainless steel welded to aluminum to showcase some of his work. Got extensions welded on, then had to go to a friend's place that had a drill press and a bridge port mill that had enough reach to work over the plate.
Took it home, test fit (LIKE A GLOVE! MEH MEH MEH!) and now the paint is drying.
I'll try and post here and there, and a writeup will follow at some point after the car is on the road.
Old 09-03-2012, 10:27 AM
  #266
WarShrike's Avatar
Almost there, had to put in new knock sensors. That meant taking out the pass side engine bracket, whick meant I needed to take out the AC compressor lol!
Finally got to a broken bolt as well, came out easy, apparently I didn't hit that one with lock-tite...
Old 09-05-2012, 05:05 AM
  #267
WarShrike's Avatar
So for the first time since April 13, the Firebird went for a drive. Fired it up yesterday after doing the T-56 swap, took a lot longer to do than anticipated, but it is done!
Need to re-tune it and do some final adjustments along with putting the rest of the interior back in the car but I am happy to see the car running.
Old 09-07-2012, 06:59 PM
  #268
Gotit4cheap16's Avatar
Wonderful project man. I own an L67 Supercharged Impala ss and will be installing a VS cam in it soon.
Old 09-08-2012, 09:51 PM
  #269
WarShrike's Avatar
Nice, you planning on getting it tuned locally or just mail order?
In other news...
Interior is all back in the car, new carpet is in, wish I had done it slightly different but got rushed (single guys take note lol!)...
Also, this car feels like it is an entirely different machine, looking forward to finishing break in and get some tuning done hopefully this week. It is also so much quieter with the rear panels and seats back in, rather nice.
I did take my wife and 2 month old out for a drive though, car seat fit perfectly in the back, my wife is only 5'5" so she fit fine up front in the Corbeau CR1's. Went and got the car washed and picked up some Blizzards at DQ. Oh what a feeling!
Pics later, gonna hit the sack...
Old 09-09-2012, 02:09 PM
  #270
WarShrike's Avatar
Old 09-17-2012, 11:35 AM
  #271
I plan on getting it locally dyno tuned. I was told to get the best HP numbers and tune to get a dyno. Just installed it 4 days ago and love the new power. This was the last mod i wanted to do before i started modding up the trans.
Old 09-21-2012, 04:16 PM
  #272
bogger01's Avatar
i might have missed it but what headers are you using. i am doing a carbed sbc swap/
Old 09-21-2012, 10:32 PM
  #273
WarShrike's Avatar
I'm running a set of custom longtube headers built by Tiago and Patrick from Force Fed Fabrications down in south Texas.
Here's a pic after I had the slip fit flanges welded on and a repair to one of the collectors. They had v-band clamps on them from the previous owner and I always had clearance issues with them.
Old 10-08-2012, 10:35 PM
  #274
WarShrike's Avatar
Had some fun, went out on Saturday and froze my butt off. Somebody snapped some pics and I found them on facebook. I've got plans on taking some really good pictures. Car needs a repaint bad as you can now tell.
That's on Konis/Stranos on the lowest perch with 1/2" spacers on the wheels to flush them out a little better.
Old 10-23-2012, 05:09 PM
  #275
Scooty454's Avatar
Default John ginter
If anyone knows how to get in touch with john ginter please let me know
Old 10-30-2012, 08:24 PM
  #276
WarShrike's Avatar
Send a PM to gectek.
Old 10-30-2012, 08:26 PM
  #277
WarShrike's Avatar
As evidenced in my other thread, took some pics.
Yes, I know, the tint is bubbling in the back. That's on my to do list.
Old 10-31-2012, 10:10 PM
  #278
Luke Powell's Avatar
WarShrike Great read, also love what you did to the V-6,
Will be going back to reread and take notes this time, Just picked up a 97 Formula vert with a v-6 That might need a overhaul.
But anyways glad you did this.
Old 11-15-2012, 05:03 AM
  #279
eddieY87's Avatar
Great build man. Car looks great and is definitely different. Props
Old 11-19-2012, 09:40 AM
  #280
Verocious's Avatar
Damn awesome much respect to you sir (:/
Quick Reply: Project V6 Firebird
