Project V6 Firebird
Old 02-09-2010, 11:43 PM
  #41
Wesmanw02's Avatar
Originally Posted by WarShrike
And, do you think anybody will notice something odd when I pop my hood? Other than the obligatory, "Wait this isn't a V8?"
Electronic throttle body??
Old 02-10-2010, 01:56 PM
  #42
WarShrike's Avatar
Heh, yeah that's good for 50hp right?
Old 02-10-2010, 02:16 PM
  #43
Wesmanw02's Avatar
What is it off of?? A late model 3800 Series in a FWD car??
Old 02-10-2010, 02:18 PM
  #44
LS1Tech Sponsor
Beau@SDPC's Avatar
No. The 00 and up F bodies (IIRC) have drive by wire TBs on them. DBW is nothing new to GM.
Old 02-10-2010, 02:22 PM
  #45
Wesmanw02's Avatar
Well I knew that, but I didn't realize the F-body V6's got it that early. The LS1's were cable throttle all the way up to '02.
Old 02-10-2010, 02:25 PM
  #46
Trans Am Jam's Avatar
go 60 trim precision turbo please
Old 02-10-2010, 02:28 PM
  #47
LS1Tech Sponsor
Beau@SDPC's Avatar
Trying to judge the v6 f bodies off of the V8 isnt the best way to compare. There are a few similarities and quite a few differences. The FWD cars were cable until later on. Circa 04 or so. Plus the RWD 3800 also had 2 diff intakes, one the TB comes off at an angle, the other it pokes out straight.
Also the LS1 GTO was cable as well, but there were quite a few cars already doing the DBW including most of the trucks.
Old 02-10-2010, 03:32 PM
  #48
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
And GTO's up to '04
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 02-10-2010, 03:33 PM
  #49
LS1Tech Sponsor
Beau@SDPC's Avatar
Originally Posted by Matt@Texas-Speed
And GTO's up to '04
right above you there matt.
Old 02-10-2010, 05:15 PM
  #50
DOH! Must have skipped that one Good call!
__________________
Old 02-10-2010, 11:02 PM
  #51
WarShrike's Avatar
Thanks guys, yeah the switch from cable TB to electric TB happened after 1998. Of course in 1998 the cars had a new front end style, allowing for more hood clearance and the new straight intake with electric TB came in the 1999 model cars.
I would go forced induction, but as I mentioned earlier in the thread I can't afford to do it correctly right now, so I won't do it at all.
Old 02-11-2010, 02:44 PM
  #52
Wesmanw02's Avatar
Thats a good philosophy to have, saves a lot of headaches later on.
Old 02-17-2010, 11:34 PM
  #53
WarShrike's Avatar
New gaskets picked up today, started putting in the QA1's. Gotta get new bottom bolts for the rears...
I have the front end back down on ramps and holy crap I need to lower that thing alot more! Car has like 4 to 5 inches of fender gap haha! That's what I get when I swap from an LS1 car with a full turbo kit up front. I even lowered the height an inch before putting the wheels on. I'll do it after everything else is done on the car, will make it easier to crawl around under there for the time being. Gotta pull off the headers and the whole top end tomorrow before I head off to work.
New wheels are shipping, should be in on Monday. Time to start looking into a nice set of sports tires for them...
Old 02-24-2010, 10:22 PM
  #54
WarShrike's Avatar
Okay finally grew a sack and pulled the intake off. Nothing like working on a 30 mile old engine
Old 02-25-2010, 10:21 AM
  #55
whitdog54's Avatar
good work man. I need to get my intake off to try and fix a sticky lifter.
Keep us updated.
BTW that battery you have is that the factory battery? I have the same one and was curious if its what came from the factory or just cheap autzone replacement.
Old 02-25-2010, 12:20 PM
  #56
WarShrike's Avatar
Cheap autozone replacement. I thought I killed it after starting the car after the build, but it just didn't get charged enough after a few starts.
I've had it for 6 years now...
Old 02-25-2010, 03:09 PM
  #57
Autocraft is actually Advance Auto Parts brand....it's made by Johnson Controls, and that titanium is their "best" line with the 3 year free replacement warranty.
Dane: What are you tearing it down for? I missed what went wrong....what's up?
__________________
Old 02-25-2010, 10:36 PM
  #58
WarShrike's Avatar
Cometic MLS gaskets were weeping, having to pull it to spray all three layers front and back w/ copper spray. I had already teflon'd the head studs, so I'm going to check and make sure the deck is nice and level...
Old 03-10-2010, 12:25 AM
  #59
WarShrike's Avatar
From the past week, should be putting it back together after my midterms tomorrow
Old 03-11-2010, 12:15 PM
  #60
Project382's Avatar
Nice build I like it! love the valve covers.
Did you figure out why your head gaskets were leaking? What brand where they? You should not have to spray MLS gaskets down with anything, most MLS head gaskets have silicone bead applied to the gasket so you don't have to. The only thing I could think of is the block deck or head deck is not the right RA.
Quick Reply: Project V6 Firebird
