Project V6 Firebird - Page 4 - LS1TECH
Project V6 Firebird
Thread Tools Search this Thread
Old 03-11-2010, 01:11 PM   #61
LS1Tech Sponsor
No silicone bead on cometics. They do have a coating, but I have yet to see a silicone bead.
Heads were recently milled, but the block is a short suspect right now. We shall see
Beau@SDPC is offline   Reply With Quote
Old 03-12-2010, 09:51 AM   #62
hmm, most mls gaskets especially head gaskets get a coating of silicone sprayed over to help cold sealing. however if the RA isnt right they will slip and cause a leak. Other head gaskets that have a colored line have a embedded silicone line and then are sprayed with the silicone coating.
Did you change the head bolts? If they were torque to yield they might be stretched and are not applying the proper load.
Project382 is offline   Reply With Quote
Old 03-12-2010, 09:57 AM   #63
example of silicone coating with no embedded silicone bead
example of embedded silicone bead, this also has a clear silicone coating
Old 03-12-2010, 10:02 AM   #64
LS1Tech Sponsor
The gaskets you posted on the last picture.....are you sure they are for a 3800 and from cometic?
Old 03-13-2010, 11:11 PM   #65
WarShrike's Avatar
Project382, it might be the RA, but many people in the 3800 community have issues with them even after properly treating the heads and blocks. It is something else that guys have to do in the Grand National community too. Must be something with some of the similar architecture.
I am using ARP head studs.
And the gaskets are the sprayed layers, there aren't any silicone beads at all on mine. They're from Cometic. I pulled the new ones apart and sprayed them with copper spray after cleaning them. They were FILTHY!
And John, those aren't 3800 gaskets by any means, coolant holes are in the wrong places.
WarShrike is offline   Reply With Quote
Old 03-16-2010, 01:56 PM   #66
LS1Tech Sponsor
I knew it looked diff. Looks like 60* stuff.
Old 03-17-2010, 10:35 AM   #67
No those are not 3800 gaskets. I just put up examples of the silicone John was talking about, and why it was there so you dont have to spray copper gasket sealer on MLS gaskets. In fact I have had many customers blow head gaskets after applying copper sealant. I think the top one was a 6.0L Powerstroke and I cant remember what the bottom one was. I was just trying to show examples the silicone coating. Cometic should use a clear silicone coating, I would find it hard to believe they dont use any.
But good luck The build looks sweet.
Old 03-19-2010, 08:47 AM   #68
WarShrike's Avatar
Up and running again, time to tune!
http://www.youtube.com/watch?v=xyVjFEK_70c
Old 03-19-2010, 01:35 PM   #69
LS1Tech Sponsor
Awesome
Old 03-30-2010, 11:20 PM   #70
WarShrike's Avatar
Did some data logging today. Car needed more fuel on the trims, so I adjusted that and will see what it does tomorrow. Open headers + turndown extensions right below your seat == threshold damage. And I haven't even gone WOT nor tapped redline yet
Old 04-06-2010, 09:00 PM   #71
1994formulalt1's Avatar
nice build. different. a buddy of mine did a cam only 3.8 on his bird he went like 13.8 i believe
1994formulalt1 is offline   Reply With Quote
Old 04-06-2010, 10:43 PM   #72
WarShrike's Avatar
13.8 Is a reasonable number, especially on the regular off the shelf grinds. Picking up 2 seconds or more in the 1/4 over stock with a cam only is a vast improvement in any bracket.
Would be very thrilled to see 13's at our altitude.
Old 09-30-2010, 05:26 PM   #73
layz's Avatar
that thing does not sound like a v6 with the exhaust on...
layz is offline   Reply With Quote
Old 09-30-2010, 08:17 PM   #74
WarShrike's Avatar
Thanks, one of the guys at the shop I frequent was under his corvette and heard me pull up (exhaust on). I walk in and then he sees the car and was like, "Oh, I thought a diesel had pulled up."
Old 11-10-2010, 08:58 PM   #75
RedVertTA's Avatar
Any updates on the project?
RedVertTA is offline   Reply With Quote
Old 11-11-2010, 08:58 AM   #76
LS1Tech Sponsor
He is DDing it now. Tuning a little. The V6 are a little finiky when it comes to tuning. So you have to tune a little and drive alot. So that is the process right now.
Old 11-13-2010, 03:17 PM   #77
WarShrike's Avatar
Hah, just saw this thread was thinking of updating it.
Yes, this car has been a bit moody, little things that just irk me lol! Waiting on the semester to wrap up so I can have time to install the LS6 injectors as the current stockers (19lb/hr.) just won't cut it.
Old 11-13-2010, 03:44 PM   #78
82cetuner's Avatar
I want to see dyno numbers.
82cetuner is offline   Reply With Quote
Old 11-14-2010, 12:01 AM   #79
WarShrike's Avatar
You and I both, along with everybody that had a hand in this build
Old 12-07-2010, 10:42 PM   #80
WarShrike's Avatar
Finals are almost done.
Aaand, I just got a little front page face time on Bang Shift
LINK: Clicky
Related Topics
Thread Thread Starter Forum Replies Last Post
New wheels came in. WarShrike Wheels & Tires 44 07-03-2016 10:42 PM
Speedline Mistral 6's 17x9.5 ET48 WarShrike Parts Classifieds 3 05-18-2016 01:23 PM
LS1 PCM to V6 and 24x reluctor vs 18x. WarShrike Advanced Engineering Tech 2 03-26-2015 11:50 AM
Corsa Clones WarShrike Appearance & Detailing 7 02-24-2012 03:44 PM
Project Flyenlow: 3.4 V6/T5 to LT1/T56 swap tbird31 Conversions & Hybrids 36 11-28-2010 08:47 AM
Tags
3800, 38l, 98, a4, driveshaft, firebird, installing, lid, rockers, roller, terra, v6, whisper, whisperlid, yella
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
