Rear End Question
Old 02-06-2010, 12:17 AM
ripfirebird94's Avatar
Default Rear End Question
What's up fellow bird lovers? I recently purchased a 1994 firebird formula. I want to get a 0-60 time that's the full lt1 power. The problem is I'm afraid if I floor it I'm gonna drop my automatic transmission or lose my rear end. The 94 has a transmission preform button and it shifts pretty hard. The car has 125k (just turned) on the odometer. Can I floor this car without worrying about causing major damage?
I've gotten my 0-60 with about half pedal (6.3)
Old 02-06-2010, 12:18 AM
and the car is stock besides a cold air intake
Old 02-06-2010, 12:38 AM
bump.
Old 02-06-2010, 07:18 AM
LS1W66's Avatar
If the engine is stock you should be Ok but heres a tip "as long as the tires are spinning you won't break any parts".
Old 02-06-2010, 11:46 AM
mannyman84's Avatar
you should be fine if the engine is stock...the rear end and tranny are designed to take the stock power up to a certain point...if the car hasnt been driven hard before, try not to give it its all..gradually build up your trust in it
