Mod advise for my LS1 T/A
Old 02-28-2010, 04:35 AM
garylisko's Avatar
Default Mod advise for my LS1 T/A
Hey guys, Im looking to do some effective mods to my 2000 Trans am. Has 80k miles, 6spd, slp catback, k&n CAI, Hollowed out cats. I have around $800 to work with. Plan to get used "in good condition parts" to hopefully get more for my $. My goal is to be in mid to low 12s by spring. I want to know what mods have seen the most gain for the money. I live in Sarver PA, would like to pick up localy, if you have something you think I'd be interested in, PM me, email me at ilc716@yahoo.com or call/text 412 403 9941 (It wouldnt let me post on parts wanted) Thanks.
Old 02-28-2010, 08:19 AM
LS69TA's Avatar
Longtubes, tune and gears if you can affford them all.
Old 02-28-2010, 01:11 PM
joblo1978's Avatar
drag radials too
Old 02-28-2010, 02:22 PM
garylisko's Avatar
What do u think Lts, 410s and a tune would get me? That is one route i'd like to go. I'd like to do a cam at some point, but i think 410s would really help. And as far as long tubes. The cheaper ones on ebay, is the gains less compared to the bigger names like slp & hooker?
Old 02-28-2010, 11:43 PM
garylisko's Avatar
I'd like to get a good cam set up, hardened pushrods, lifters as a package deal, and lt headers. Cant post in wanted add..
Old 03-01-2010, 08:45 AM
whitdog54's Avatar
pacesetter LTs, tune, and some sticky tires should put you right where you want to be. Maybe a little weight reduction too.
Old 03-01-2010, 01:22 PM
LS69TA's Avatar
Pick up some used pacesetter longtubes and a used dry kit and those will get you there with some drag radials..then start saving up for a new rearend.
Old 03-01-2010, 07:13 PM
garylisko's Avatar
I would like to post a wanted add up but for some reason, the site will not allow me?
Old 03-02-2010, 01:31 AM
garylisko's Avatar
If i did, pacesetter LTs, ls6 intake, ported TB and underdrive pulley, what kinda of gains could i get in that combination and would it put me in the 12s?
Old 03-02-2010, 01:50 PM
batman_ls1's Avatar
i have a 00' T/A mine is doing 12.9 with this set up
pacesetter Lt's ORY straight 3inch all the way back
85mm T/b
centerforce clutch and new slave
i wouldn't recommend drag radials with a stock 10bolt especially with the 6spd
Old 03-02-2010, 08:21 PM
Ironxcross's Avatar
the main thing with drag radials and a 6 speed is to NOT dump the clutch. shock the drive train and the 10 bolt goes boom.
if you slip the clutch just right, you should be fine.
Old 03-03-2010, 01:47 AM
SteelOCircle's Avatar
Will do. Gotta respect the advice of anyone who has had first hand experiences with these things...
Old 03-03-2010, 07:00 PM
garylisko's Avatar
Well, as of now im going with this set up: QPT LT headers, Weiand/Ligenfelter intake manifold, 80mm BBK TB. Anyone have this set up?
Old 03-05-2010, 12:51 AM
garylisko's Avatar
I found cam packages with hardened pushrods/valve springs on texas speed.com which is next on the list. Need to find a nice agressive cam that i cant street and see nice gains from. Any suggestions? Also, was looking at their head/cam package, paticularly this one: PRC 220cc 5.3L Stage 2.5 CNC Ported Heads, does anyone have experience with this set up? I'm wondering the gain increases with that package vs a cam package. Is it worth doing for the $ or stick with just the cam?
Old 03-05-2010, 12:18 PM
LS69TA's Avatar
Stay away from the aluminum manifold. It soaks in alot of heat. Get a Fast intake.
Old 03-06-2010, 12:13 AM
garylisko's Avatar
A buddy of mine has a set of ls6 heads hes not using, I could probably grab at a decent cost. Means Im going with a new cam set up, would ls6 heads be worth considering as an option?
Old 03-08-2010, 08:28 AM
FreebirdWS6's Avatar
Ls6 heads wouldnt be bad to go with,I bought the PRC 220cc stage 2.5 5.3 heads to go with the MS3 cam I also bought,Im waiting to install cuz I dont know much about the cam cuz Im still gunna daily drive it.
Old 03-08-2010, 09:20 AM
Platinum WS6's Avatar
oh wow..here we go with the heat soak crap again.....my weiand put down more power than the LS6 intake did fyi but I guess I forgot to tell the dyno it was an aluminum intake....
the fast is better yes but its also $1200 with the Tb to go with it. If you can pick up a weiand or ls6 go for it b/c with your $800 limit you wont even get the fast
Old 03-08-2010, 08:55 PM
cbr600rx7's Avatar
I would say MT dr's, cam and valve springs, with a good tune would get you into the mid 12s with no problem. But then again it might be hard to fit that under you budget of 800. If you have good tires then drop in a 22X-23x cam with good valve springs and get a good shop to tune it in for you and you should be good to go.
Or hook up a bottle and go for 11s
Old 03-08-2010, 09:48 PM
V8MUSLE's Avatar
i just got finished putting a bbk lt and ory on i already had the slp lm1 catback it sounds awfull above around 2.5k. trying to find a magnaflow to replace it.
Quick Reply: Mod advise for my LS1 T/A
