Strange headlight issue
so i was driving to work yesterday and my headlights came up with out me touching the switch. i then had to move it back and forth like 15-20 times for them to go down only for them to come back up again in like 10 min. this even happened when the car was off. i parked it with them down and i cam back to them being up! what is up with that! is there a way to fix this? it is both headlights, but they only go up and do not turn on unless i turn the switch on. any advice welcome
I'd guess a short somewhere... but as where to start looking? hmmm
Is there a relay that actuates the motors? I would look for that, I've had burned relays that will do funny stuff like that.
so still haven't figured this out, i pulled the fuse so no headlights right now. is there a main box or module that controls the headlights? cause that is what i am thinking, that it is a bad relay or connection. cause the switch is not bad and the fogs done come on at the same time, so it has to be a motor control or relay issue, or something....?
