02 WS6 Issues... PLEASE HELP!
So the other day my turn signals stop working completely (relay or switch im assuming) and now this morning the A/C fan does not come on AT ALL. Which fuse/relay is it so I can check it or is there another issue I should be worried about? thanks!
pull the fuse cover off the left side of the dash (its hidden by the door), and check all the fuses and relays there. on the turn signals, it could be the turn signal relay which is located under the dash to the right of the steering column. it's round about 1" dia. you cant get an eye directly on it, so you will have to feel around for it.
for the A/C check those relays as well. if nothing else your BCM could be going out. it's located under the glove box compartment on the passenger side and entails removing some interior trim pieces to get access to in order to remove and inspect it.
there is a sticky in regards to the BCM, so I would suggest doing a search if the above does not solve your issues. good luck!
