Need help
Old 05-16-2011, 03:11 PM
georgiasmurf's Avatar
Default Need help
my 01 ws6 is haveing trouble when it rains the car starts to spuder and kick and i have no clue whats wrong with it any ideas plz help
Old 05-16-2011, 03:49 PM
piercecamaro's Avatar
you most likely have a spark plug problem what you can do to check get a spray bottle and mist the plug wires with water while the engine is running if it starts spudering you know it is the spark plug wires are bad.
sounds like what is happening when it rains moisture is getting under your hood and you likely have some bad spark plug wires and it is causing them to missfire.
if you do it at night you probably will be able to see them arking when you spray them
Old 05-16-2011, 04:40 PM
AwsmGy's Avatar
If that's the case and your wire is bad, I have 2 OEM wires that I was about to trash. If you pay the ~$3 shipping or whatever they're yours.
Old 05-16-2011, 09:40 PM
thanks guys ill try that and i got the wires just didnt kno what my problem could be
Quick Reply: Need help
