Help!!
Old 07-24-2011, 11:53 PM
super2391's Avatar
Default Help!!
I recently took my 02 Firebird into the shop to have a new clutch put on. A few days after I noticed that my trunk latch button was no longer working, and a few days after that when I tried to use my windshield wiper fluid to get some dirt off the windows no liquid came out but the wipers came on. The fluid tank is full and the fuse for them is not blown. Has anyone else ran into this problem, and how did you fix it?
Old 07-25-2011, 12:10 AM
guy7bmwm83's Avatar
Are the nozzles clogged? Try using a needle to see if the tips are clogged. My truck would do that and I would use a needle to unclog the crud.
Old 07-25-2011, 12:33 AM
Suzaku's Avatar
Sounds like your shop is stealing fuses.
No idea, the clutch installation might be causing the problem, most likely worksmanship and then it might not be.
Old 07-26-2011, 07:47 PM
super2391's Avatar
Thanks guy I'll try that, and Suzaku all the fuses are good on it and accounted for.
