93 bird optispark?
Old 09-19-2011, 12:02 PM
astan84's Avatar
Default 93 bird optispark?
took the opti off and replaced the cap and rotor put it back on and now it turns over but wont start?? should i have just replaced the whole distributer? im stuck.
Old 09-21-2011, 01:58 AM
ws6transam98's Avatar
I will ask my friend about this on Thursday if you haven't gotten any responses. He has messed with a lt1 a lot more then I have. I do know they can be kinda pain to mess with. I'll post back on Thursday.
Old 09-21-2011, 11:25 AM
Ocala93TA's Avatar
I would do one of two hings either take it back apart and recheck to see if its correct or buy a new one . If you take it apart again , put locktite on the outside screws so they wont back out .
Old 09-21-2011, 11:56 PM
on1wheel01's Avatar
Yea like said take it back off check all connections and such
Old 09-24-2011, 04:03 PM
blacksmith73_99's Avatar
make sure the dowel pin is inserted properly. if it is, time to replace the whole thing. get ready to do that job a few times unless you can still purchase the MSD version of the optispark. that was the one thing i hated about my 93 Z28
Old 09-26-2011, 10:11 PM
astan84's Avatar
thanks, this is a pain taking it back apart again tomorrow night. hopefully this is the last time.
Old 09-26-2011, 10:15 PM
astan84's Avatar
Angry
went ahead and replaced the whole unit. runs now but not very well and now has a ping when accelerated. guess ill just take it apart again
Old 09-27-2011, 12:17 PM
Ocala93TA's Avatar
You replaced it with a new opti then it shouldnt be the opti unless you didnt line up the dowel pin correct on the opti . if it pinging in high rpm sounds like a plug problem . Have you replaced them ?
Old 09-27-2011, 07:19 PM
astan84's Avatar
tep plugs and wires. im thinking the pin went in slightly off and is throwing the time off. trying to find top dead center now. the splined pin is only supposed to go one way but it doesnt seem like is the way it should have went in.
Old 09-28-2011, 12:50 AM
astan84's Avatar
What direction should the metal side of the rotor button face at tdc? Trying to figure out if I could be out of time. The plastic side faces number 1 on the compression stroke.
Old 09-28-2011, 07:59 AM
on1wheel01's Avatar
Here is a complete write up on it, it's what im gonna use when I do mine
http://www.firebirdnation.com/forums...k-replacement/
Old 09-29-2011, 12:51 AM
astan84's Avatar
Got it! Splined pin was slightly off. Putting it back together again. FYI the how to link above is slightly off. Good luck getting that balencer off.
Quick Reply: 93 bird optispark?
