help with strange problem
Ok guys 95 trans am no cats car started running rough at times. Then it will go back to normal then back again. I'm stumped I haven't had the codes ran yet but my cel is always on since no cats.
Ok guys had the codes ran. They didnt give me code numbers just said this. They came up
EGR valve Injector circuit, air circuit.
Any ideas?
Also I cleaned my maf and it looked pretty clean
Any ideas?
Also my egr valve and such have been removed.
I also have a vac line that has been unhooked since I got the car I cant find where it would go. It's the first nipple from front connection off the intake on drivers side
Ok guys I figured it out. I started checking my fuel injectors and such. And I found I had a loose connection on one of my injectors. So shes good now. Thanx for all the help.
