Does and donts with this car?
Old 12-07-2011, 12:35 PM
MN.marine.'s Avatar
Default Does and donts with this car?
Got a ws6 what are some things I should and shouldnt do?
Old 12-07-2011, 01:59 PM
Guitar's Avatar
Do: drive it.
Don't: dump the clutch repeatedly at redline.
Do: smoke ricers.
Don't: rice it out.
Old 12-07-2011, 02:25 PM
ghardester's Avatar
Keep it out of the ditch.
Seriously, what do you have in mind to do to the car?
Old 12-07-2011, 04:23 PM
Fry_'s Avatar
Do use the car to pick up chicks.
Don't crack your center console trying to do it in the car.
Old 12-07-2011, 05:51 PM
MN.marine.'s Avatar
haha...I wanna try to get some good 1/4 times but yet use it as a DD..
Old 12-07-2011, 06:44 PM
sway99bird's Avatar
Upgrade the rear end !!
If I could go back that's what I would have done first !
Old 12-08-2011, 05:46 AM
Suzaku's Avatar
I wish someone told me that sooner...
Old 12-08-2011, 06:17 AM
Captain Double Post
BOBS99SS's Avatar
so when can we expect a ,what cam,exhaust,etc thread lol, be smart if your going to mod research or just plan on blowing money on pointless junk, have a goal in mind , and a good build plan, stick to it, dont race in areas where others are in danger, sometimes these cars have a mind of there own ,
Old 12-08-2011, 06:24 AM
staleycornell's Avatar
DO...the door panel mod so they dont become cracked!...unless the dreadful is already there
DON'T...ever sell it to buy a Ford
Old 12-08-2011, 06:59 AM
That's MISTER MODERATOR
Paul Bell's Avatar
MN.marine, welcome to LS1tech.
If you told us more about this car like it's year and transmission, we might have more specific advise for you.
Old 12-08-2011, 07:26 AM
MN.marine.'s Avatar
Well shes a 2001 ws6 M6 with 88,000 miles. I bought it about two weekend ago, its has a cam, prc stage 2.5 heads, longtubes, bbk tb.
Old 12-08-2011, 07:42 AM
Captain Double Post
BOBS99SS's Avatar
take it easy on launches if it still has the 10 bolt, a m6 car will pop them in no time , intake and injectors? your really going to have to give us all the lil details ,
Old 12-08-2011, 07:46 AM
Paul Bell's Avatar
A good tune up, wires, plugs. Oil change, Mobil One Extended or K&N oil filter. Air filter (NO oiled K&N type). Trans & rear end fluids (NO synthetic rear end fluid!). Coolant flush. Brake pads & rotors (blanks, of course). Poly sway bar bushings and end links.
Post up pics of this thing.
Here at LS1tech, https://ls1tech.com/forums/search.php is your very best friend.
Old 12-09-2011, 08:13 AM
MN.marine.'s Avatar
Well the only things I know about the car for mods is what I listed. For exhaust, duals with a x pipe. It also has the smooth bellow. Why is it bad to run oiled filters?
Old 12-09-2011, 08:15 AM
Paul Bell's Avatar
They have been known to deposit an oil film on the MAF.
Regular paper filters are just as good and way less costly. This is one area where there's a lot of hype.
Old 12-09-2011, 09:04 AM
cemlsx's Avatar
^ +1 for that , those damn things are expensive too
Old 12-24-2011, 01:59 PM
777Shock777's Avatar
I agree with all of the above ^^^
Except, I have seen that he SHOULD use synthetic fluid for his rear end.
I did a lot of research into this and if you have the limited slip diff, (99 & higher), he should be using synthetic fluid.
I have a 99 WS6, and even my owners manual says to use synthetic.
I'm still kinda learning here, so if I'm wrong please correct me
Old 12-24-2011, 02:30 PM
Paul Bell's Avatar
hehehe I hope to learn something every day!
Eaton posi units should NOT have synthetic fluid used with them. It'll stop being a posi.
The pressures and temperatures in the rear is way less than in an engine and the stresses are way less. Plus, synthetics have the propensity to get past rear seals quicker.
I use the Lucas non-synthetic in my rears. It's super sticky and is considered a "climbing" gear oil.
Old 12-25-2011, 01:36 AM
Yeah I have heard many different answers when it comes to differentials and what kind of fluid to use.
I was going to do a fluid swap on mine to some Royal Purple synthetic fluid with the GM additive, (I have heard controversy on the GM additive too).
Interesting right? >__<
