Go Back   LS1TECH > VEHICLE SPECIFIC FORUMS > Pontiac Firebird 1967-2002
Sign in using an external account
Register Forgot Password?
Register iTraderTimeslips Photos Members Search Today's Posts Mark Forums Read Vendors
Search
Welcome to LS1Tech.com!
Welcome to LS1Tech.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join LS1Tech.com today!
Thread Tools Search this Thread
Old 04-16-2012, 02:04 PM   #1
Garage is empty, add now
Trader Rating: 0
Default Swapping mufflers, drop rear end?
I searched for this but could not find a direct answer although it seems that I will have to drop the rear axle to swap the muffler, is this true?
Car is an '02 WS6 and all I want to do is drop the catback, cut off the muffler, weld in a magnaflow and reinstall. I don't have a lift, all I have is a flat floor, a few jacks and jackstands...and a pair of hands to help me out.
Is this reasonable to do or is it hopeless?
Doc74 is offline   Reply With Quote
Old 04-16-2012, 02:24 PM   #2
2002 Pontiac Trans Am
Trader Rating: 4
The stock exhaust isn't sectioned after the y-pipe. You could certainly cut the exhaust and weld in a new muffler without mucking with dropping the axle.
lees02WS6 is offline   Reply With Quote
Old 04-16-2012, 02:32 PM   #3
Trader Rating: 0
Quote:
Thanks for your reply!
I suppose that as long as I can raise the car high enough I can cut the old muffler off but that means I can't weld the new muffler on while it's off the car since I won't be able to get it all back on in one piece. This would work however if I use clamps on the muffler but I think welds would be a bit more secure.
How much work is it to drop the axle while the car's on jack stands? I'm assuming all you need is a bit of extra clearance and the axle doesn't have to be removed all the way?
Old 04-16-2012, 05:22 PM   #4
Trader Rating: 4
you can unclip the break lines from the axle tubes, take the brakes off and hang them with coat hangers or bungee cords. Detach the parking brake cables from both sides of the axle. Unplug the abs/tcs sensors at the axle and detach that cable from the axle tubes. Then remove the shocks, lower control arms, panhard bar, springs will fall out when the axle is low enough. You can unbolt the torque arm at the diff, and then take the drive shaft out. I have had the rear out of my car several times, and it can, and has been done with stands and a floor jack. Frankly that's a lot of work for just a muffler.
I would just cut the exhaust leave enough length that you can clamp it. Use some exhaust paste, and clamp it.
LS1Tech
Pontiac Firebird
Paid Advertisement
Tags
02, axle, brake, cable, cut, drop, dropping, end, exhaust, firebird, ls1tech, rear, rearend, remove, weld
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.2
Advertising - Terms of Service - Privacy Policy - JOBS
Emails & Contact Details
