Trans AM Transmission
Old 07-23-2012, 09:02 PM
Verocious's Avatar
Default Trans AM Transmission
I was researching around a bit, and my friend has a 2000 z28 Camaro A4 and its with overdrive, I have been looking for a Trans AM and I found one its a 2001 and it doesn't have overdrive? It has 3rd gear? Can anyone give me some info on this?
Old 07-23-2012, 09:36 PM
crankwalkin's Avatar
So, you are referring to the markings on the shifter bezel?
Old 07-23-2012, 09:38 PM
88gtman's Avatar
They are the exact same transmision. The gear selector just reads differently. The 3 in the Camaro is the same as D in the Trans Am. The D in the Camaro is the same as OD in the TA. Both have OD. Just doesn't show it on the gear selector. 4th gear=OD
