Lt1 sputtering at 4 rpm
Old 12-03-2012, 01:31 AM
94formular's Avatar
Default Lt1 sputtering at 4 rpm
Hey guys my 94 formula is acting up on me. Don't know what it is hoping its not the opti, maybe just a bad o2 sensor. So what happened is the check engine light popped on a couple weeks ago (i was standing at a light) and the Rpm started dropping real low like the car wanted to stall out and 5 seconds later check engine goes away and car runs fine. Up until bout week ago when I'm WOT and hit 4-4.5 rpm the cars sputters and won't go above that.usually in 1st and 2nd gear. And check engine light pops up again and goes away almost instantly. If I gradually increase rpms to 4-4.5 no sputtering.
Old 12-03-2012, 06:47 PM
Mike.'s Avatar
The first think I would do is have the code pulled.
If I remember correctly a 94 won't flash codes. You'll need an obd1 code reader.
If you can't do that then the usual comes to mind - Spark plugs, wires, maybe o2 sensors, opti.
Old 12-03-2012, 07:02 PM
94formular's Avatar
Well the code isn't on now, but spark plugs are good, getting. The car back tommorow will hopefully get the o2 sensors checked, thanks for the info.
Quick Reply: Lt1 sputtering at 4 rpm
