has anyone tried installing this system?
I found this system online and I really wanna get it to make alittle bit of a modern twist on my bird.
http://www.advancedkeys.com/Prod_AK104B.html
its a smart keyless entry system with a pushbutton start, just wanted to know if anyone has done it and how tough was it to install? any tricks/tips?
The GM Passkey system might make it difficult for that to work, if your car is so-equipped. AFAIK the resistor for the system must be present for the ignition interlock to engage. You might be able to disable this, though how, I am at all aware.
Also, I don't see anything on if it'll work with a clutch interlock. Since in an automatic you need to have your foot on the brake to switch gears, it might piggyback on that system. In a clutch, who knows.
