Volant
Old 02-19-2013, 05:21 PM
AmnSF's Avatar
Default Volant
My volant finally came so I ditched the SLP lid and bolted it in. It was a pain in the *** to some extent. Had to trim the weatherstripping a little bit and fab up some bellows but all in all it looks good. I won't post a pic since it can be easily found on google. Just figured I would share.
Old 02-19-2013, 06:00 PM
Mr Phil's Avatar
You still gonna sell me your slp and lower ram air part?
Old 02-19-2013, 07:33 PM
AmnSF's Avatar
I was going to until my neighbor magically appeared and gave me $100 to put it on his camaro ss
Old 02-19-2013, 08:28 PM
Mr Phil's Avatar
****.... He bought upper and lower?
Old 02-19-2013, 09:30 PM
AmnSF's Avatar
Yeah man
Old 02-19-2013, 09:50 PM
Mr Phil's Avatar
I thought the ss already came with a ram air
Old 02-20-2013, 09:14 AM
AmnSF's Avatar
Nope.
Old 02-20-2013, 02:23 PM
Mr Phil's Avatar
Well poop lol.... so have you noticed any difference with the volant on there? I might actually pick one up, I was looking online and people are wanting as much for a volant just for there stock lower
Old 02-20-2013, 02:59 PM
AmnSF's Avatar
Some people might call BS but I also removed my AIR pump and I punched it earlier today and the car sarted to pull harder then usual. Can't till my H/C setup for an even bigger pull
Old 02-20-2013, 03:27 PM
Mr Phil's Avatar
Nice, would like to find a dyno comparison between slp and volant
Old 02-20-2013, 03:39 PM
AmnSF's Avatar
I'm sure it wouldn't be much. ~5-10 hp maybe. But I don't have any numbers.
Old 02-21-2013, 04:24 PM
sleepinghawk's Avatar
Yea mine was a pain also, but after adding a 3.5 x 4" reducer coupling to the volant Y, it finally solved all my problems with the filters being in a bind. I just finished mine yesterday.
Old 02-21-2013, 04:34 PM
There's not alot of info but there is a little.
https://ls1tech.com/forums/generatio...-air-hood.html
Old 02-21-2013, 06:00 PM
AmnSF's Avatar
I did a 4" to 3" coupler and had to do a little "porting" to the 3" side with a razor blade.
Old 02-21-2013, 08:12 PM
HAHA Yes me too! I cut alot
Old 02-22-2013, 07:15 AM
That's MISTER MODERATOR
Paul Bell's Avatar
Even a 5 HP improvement for any CAI is high on average. If it's a ram-air type intake, it will add some power at highway speed.
As the A.I.R. pump only operates for like a minute or so when the engine is cold at first start up and it's not belt-driven, it won't add any power. It'll clean up the engine compartment pretty nicely tho.
Old 02-24-2013, 05:08 PM
AmnSF's Avatar
Removal of the ugly hoses definitely makes the engine bay cleaner AND makes it a lot easier for plugs and wires. Glad I finally got around to doing it.
Old 11-09-2015, 11:29 PM
scottie dont's Avatar
i know this is an old thread but do you have a pic of how you went from the volant to the 90mm throttle body?
Quick Reply: Volant
