flasher replacement
flasher replacement
I have a 98 firebird 3.8 auto.. anyways my flasher for my turn signals is pretty slow and loud, so I was going to change the flasher because its inexpensive... anyways can anyone tell me where its located? I know its in the cab but is it under the dash? or? sorry bout the questions thought someone would be able to tell me pretty easily rather then me take forever searching for it
Well my Flashers flash but my turn signals don't blink unless I manually blink it with my finger. .. They light up when I click iy on but they only stay lit upinstead of blinking.... do I have the same problem?
So I said screw it. I went to a junk yard, and cut off a front blinker off a Grand AM. Just about all GM cars use these. Hopped on ebay, ordered a new set of front housings, hopped on superbrightled.com and ordered the CORRECT amber daytime running lights with blinkers leds. This fixed my problem, and the front end looks brand new again. HOWEVER, if you do this you have to upgrade the flashers for leds, or they will hyper flash.
So the front driver side drl works, it flashes when I unlock the car, but emergency flashers or blinkers it won't light up so maybe the second stage of the bulb is bad or something is wrong up front with the lighting
Well last night for the first time since I owned the car the blinker worked, it worked until I shutit off andit doesn't work anymore so Idk Wtf is wrong with it :/
