'02 rear suspension
Old 04-16-2013, 08:24 PM
johnfin's Avatar
Default '02 rear suspension
I have a rear clunking noise from the rear suspension when I go over bumps. The shocks are new bill steins. Is there a common problem with these cars?
Old 04-16-2013, 08:38 PM
1320Chicken's Avatar
Tighten everything up with the suspension loaded? Could be something loose or a bushing somewhere is shot.
Old 04-16-2013, 10:21 PM
9mmNATO's Avatar
I had a noise that sounded like someone hit the frame with a hammer when I went over bumps. Everthing seemed tight. Took out the lower control arms and found one bushing was no longer glued in place. Replaced the LCAs - problem solved.
Old 04-16-2013, 10:24 PM
Zlow28's Avatar
It could be a lot of different parts. My z28 had the same problem and it was the rear sway bar brackets
Old 04-17-2013, 03:55 PM
Blackpanther99's Avatar
Could start by checking out those rubber bushings.
Old 04-19-2013, 02:05 PM
bigken's Avatar
I have a similar noise, it's the bushings in the rear lower control arms. They are shot and I am just going to order some Founders arms.
Old 04-19-2013, 03:24 PM
Restricted User
eric_cspan's Avatar
probably you're bump stops. These fixed my problem.
http://gtog8ta.com/93-02-firebird/tr...ar-bump-stops/
Quick Reply: '02 rear suspension
